Painting Floor ?
BWH
I've Installed New Plywood Floor. Should I Use Cloth Or Mat On Floor Or Just Paint Over Resined Floor, Any Help Would Be Appreciated Thanks
Bob_VT
Re: Painting Floor ?
A layer of cloth will last MUCH longer. The resin alone will crack and allow water to infiltrate the plywood. The deck will last longer and then you can either paint it alone or add in some non-slip additive (Play sand)..... or look at durabak or even a vinyl deck covering.
