Shift Cable Bellows Question
FreeBeeTony
Why is there a crimp clamp on the small end of the shift cable bellows instead of a small hose clamp?
And how do you know where to position the cable with respect to the clamp?
Don S
Re: Shift Cable Bellows Question
Basically, the bellows fits tight enough on the cable that it won't leak even without a clamp. But I usually put just a fuel line cable tie on them. The crimp clamp is steel and rusts away in salt water anyway.
The hose clamps can twist and poke a hole in the ujoint bellows if the sun and moon align improperly. The crimp or cable ties also allow the cable to slide through the bellows as needed.
FreeBeeTony
Thanks Don.....I will use a cable tie.........
Any hints on replacing the u-joint bellows? I have another thread started on that subject also.
EddiePetty
.....to continue Don's suggestions::):):)
A hose clamp of such a small diameter would not compress evenly, especially in the area of the feed screw...a sure leak would develop.
The cable will position itsefh as the drive is re-assembled and cycled through the trim range. A dap of Dawn (Don?) will easy this adjustment.
FWIW....Ed in 'ol Virginny
JustJason
When i do them I tilt the drive all the way up and swing it to the left, push the boot in a bit so its not stretched out, then use a marine fuel line zip tie. Make sure you get a fuel tie, as they are different than a regular wire tie.
