1986 VRO Trim Tilt fluid change
Brookie
I would like to change the fluid in my system. I have two questions 1 is there good synthetic oil for this? 2 Is it necessary to disconnect the lift cyl from the engine and manually tilt it forward to access the reservoir with the maximum amount of fluid in it? I mean so I don't drain the reservoir with the majority of the oil in the cylinders? Thanks for any help with this.
