Aftermarket power pack install
Crispy
I ordered a power pack for my 1998 Faststrike 115 hp two stroke. It is a 60 degree looper. Optical sensor. I had to order through a different vender as Iboats did not have these in stock. I thought I was ordering an original omc part but me thinks that I recieved an aftermarket. The part # is 765386. My question is: "This pack only has one ground lead comming out of the back. The one on my motor has two. What would be the correct install. At this point I would like to get my rig up and running.
Thanks.
Crispy
SparkieBoat
Re: Aftermarket power pack install
without looking up the part #s, I would just say that 1 ground should do the job..cannot see a reason for 2 grounds. Bolt it up and see if it works
w2much
Ground is ground. I'd go with Sparkie on this one.
Crispy
Shes Running!!!!
Shes Running!!!!
Hey thanks to all for the many solid answers and information that this forum has to offer. I started my rig on rabbit ears. She started right up. Tommorrow afternoon I will test it out chasin walleyes.
Again thanks for the many good responses.
Crispy
