As the title implies, I have little experience with electrical work and even less with boats. Presently, I have a Minn Kota transom mount trolling motor that I wire by using a manual reset circuit breaker to simply connect the wires to the battery located at the stern. I'm not comfortable with trailering the boat with the TM mounted or leaving it that way once at home, and so I put it on and take it off at the loading dock, and it is sort of a pain in the neck to connect and disconnect the wires every time I use the boat.
I have been thinking about splicing some type of receptacle and plug onto the motor/battery to make getting the motor on and off much quicker. However, I haven't figured out the best way to splice the motor wires into a receptacle/plug while still incorporating the circuit breaker into the set-up.
Any ideas as to how this would best be accomplished are appreciated. Thanks.
