I have a 16' long by 72" wide aluminum flat with a 2008 50 mercury 2 stroke. Problem is anything over 25 miles an hour and the motor has to stay trimmed all the way in, or it will start porpoising. If you trim it up and just take the hops the boat will get up to 40, but it bounces and porpoises like hell. The motor is set with the vent plate about 1 inch below the bottom of the boat. The keel is straight, and the problem exists no matter how much weight you put in the front, the 30 gallon gas tank, and trolling batteries are all up front. The only way to make it stop is to "plow" the bow down into the water, which makes the motor noticibly bog, and kills the speed to about 30 and it still bounces just a bit. It has a mercury 3 blade 15p on it. Im wondering if moving the motor up level with the bottom will give the motor less of a "lever action" and allow it to push more than try to "dig" below the boat? If not would getting a cupped, and very low raked 15p prop fix it? Im hesitant to drill holes to install the hydrofoils, or drill into the hull to install smart tabs if there is a way to fix it with motor height and prop first. Thanks
