littlelaker
- Oct 28, 2009
- 5
Hello everone. I am new to boating but have some basic knowledge about outboard motors. I am trying to figure out why my 650 3 cyl. is cutting out at full throttle. Had replaced some fuel lines to carb and cleaned and rebuilt carbs. Checked filter mesh for debris. New fuel line and bulb and 6 gal tank. Idles great in water and out with the muffs on the garden hose. Sputters on throttle. I am thinking about the fuel pump needing rebuild kit. Also wondering about a broken aluminum cowl bracket that has as mesh ground wire mounted on the top and bottom. Could this cause some electrical short. Bracket mounts at the rear of motor over and around the spark plugs. What type of fuel should I be using in this older motor? I have read not to use cheap fuel with added ethanol or a high octane fuel. Not sure what to use. Any advice is greatly appreciated. ANyone else with this or similar motor around? Feel free to PM.
