6 Hp Evinrude
WHEELIE BOB
Started Running Slower And Slower Now Wont Start Has Spark On Lower Plug Only Points Open And Close Fine Would Only Run In The Start Position Before The Trouble
Vic.S
Re: 6 Hp Evinrude
So it's a fairly old one if it has points ignition.
First suspect would be the coil for the upper cylinder.
However, it could be the condenser, it could be the Ht lead. It could also be the plug if you are only checking the spark at the plug .... check with a spark tester or swap the plugs over.
It is worth checking the points properly too.
You post is difficult to read.
Use upper case (capital) letters to start new sentences only, not for every word. Also end each sentence with a full stop, or what ever you call it in your part of the world.
