I`m on my second thermostat in 3 months.
I originally had an overheat issue that I noticed while charging my batteries in the driveway. Good find I figured. Better on the trailer than in the water.
I pulled the engine circ pump and it was in excellent condition. I then pulled the thermostat and the lift pin under the part that rises when the temp comes up was pushed through the top making it impossible for the thermostat to open. So, thermostat got replaced and the engine still overheated. So, the water pump impeller in the sterndrive got replaced and all was well, for about four hours. I was out yesterday doing some trolling and the engine started getting HOTTT!
I shut down and let it cool off a little and decided to pull the thermostat. When I lifted it out the lift pin fell out from inside the thermostat. I put the housing back together w/o the thermostat and it would still overheat at speeds less than 1000 rpm, but over that and it would cool OK.
I got home OK and pulled the raw water supply hose off at the thermostat housing for a few seconds while doing a flush and it appeared that there was good water flow from the outdrive.
I`m stumped. What`s up w/the thermostats?
The engine is a raw water cooled Merc 165 hp in line six w/ alum manifolds and riser.
Has anyone had any similar experiences?
