1996 johnson 115 no spark on one side
i have a johnson 115 and im not gettin fire on 1 side ive checked and replaced everything that you coul from the power pack to the coils to the stater now when i replaced the power pack i got spark on 1 side which was more than i had before any advice would be helpful thanks oh and i checked compression also
Faztbullet
Re: 1996 johnson 115 no spark on one side
Check your shift switch as it will kill one side if out of adjustment or stuck. It is on starboard side of engine where cables are.
Chris1956
I did not think the V4s had shift assist switches. What about the S.L.O.W. system? SLOW kills spark to 1/2 the motor.
