2005 Nissan 3.5 hp 2 stroke
freddyray21
guy brought this to me as it would not run right and he said never has since it was new. Why he didn't take it back to the dealer I don't know, but I found the intake was sucking air and did locate a parts manual online (should have bookmarked it). The intake was missing the oring that seals it off. Got a new oring and now it idles and runs okay except. There does not appear to be a spark advance on this motor. No connection from the throttle linkage to the spark like I am used to on older motors. The result I am seeing is if you advance the throttle too quickly it dies, but if I advance it ever so slowly then no problem. Any ideas?
pvanv
Re: 2005 Nissan 3.5 hp 2 stroke
Parts catalog is available at Elvin's website: http://www.internetoutboards.com/PartsCatalogMenu.htm
A service manual is available from any Tohatsu/Nissan dealer.
No, there isn't any mechanical spark advance on these; It's all electronic. These motors are almost indestructible.
Sounds like either the initial timing may be off, or, more likely, the power circuit in the carb is a bit lean. Also check the reeds.
