realoldsalt
- Sep 2, 2009
- 7
I'am working on my boat which has a 1996 mercuriser 5.7 210 hp engine serial #OF879866. I think it has a thunderbolt V ignition ,but without the knock sensor. In as much it doesn't have the purple/white wires like one with a knock sensor, is there still a wire that needs to be grounded like the one with the knock sensor. I tried to time it today and it wouldn't run if I set it at 10 dregrees BTDC . I had to get the new decal because the old one was missing on the balancer,could I've put it on wrong. This engine is the one with a timing mark on engine itself, and the degree label is on the balancer.From the manual I think I put it on the right way, I need all the help I can get , this has been a real pain in the neck.
