Re: Wiring 24volt system
I don't know what you guys are talking about because there is no way he is getting 24V to his motor.
The only way you would get 24V at the outboard is if you removed the ground going from #2 trolling battery to the start battery and then put a ground from the #1 trolling battery to the start motor. As long as that never happens, not a problem.
I stand by my statement that this setup is flirting with disaster. Any connection (on purpose or accidentally) to the isolated troller battery ground can put 24 volts on the motor and accessories.
Yes, I jumped the gun too in saying that there would be 24V at the switch as there won't be 24V. BUT,,, I'm sticking with my recommendation of flipping the jumper wire and pulling 24V off where the jumper wire was before. I wouldn't connect the battery switch to the trolling motor's 24V + connection, because as ST said, it's flirting with disaster. Connecting the battery switch in the middle of the 24V bank will have less of a chance of smoking something. As it's wired right now, if the 24V - lead were to ground out for any reason, you would get 24V to the battery switch. All the stars would have to align for disaster to strike (switch on bank #2 when 24V hit ground) but I wouldn't tempt fate.
Something else to think of, you should have have a breaker on each batteries + terminal in the 24V bank if you are going to run the batteries far apart. It's a given you will need a breaker on the +24V terminal to protect the TM (and wiring), but should also have one in the middle of the bank to protect the long wire(s) going to the bow of the boat, in case it shorts out.
BTW, there is a way to charge both TM batteries from the alternator if you use a Marinco 4 pin 24V socket/receptacle. If you take a 4-pin Marinco TM plug and reconfigure it so the batteries are paralleled (instead of connected in series) you can plug in the "charging plug" while running long distances to help top off both of the TM batteries instead of just one. Marinco makes a red "charging" plug which you are
supposed to wire to a battery charger, but I'm not sure if this plug is parallel jumpered. I just took a spare TM plug and parallel jumpered it, instead of buying the red charging plug. If I'm running 20-30 miles I plug in the "charging plug" to charge both of the TM batteries a bit, instead of just one. I have a 100 amp alternator, so the batteries don't get discharged too bad if I run a 1-2 hours a day, depends on the TM usage though. I'm not saying this will keep the batteries completely charged, but it will put some charge back on the TM batteries while running long distances. Could be the difference of the TM batteries being dead at the end of day 1 or the end of day 2, depends on the output of your alternator.
http://www.marinco.com/product/chargingtrolling-system-package
