vicksburgbillie
- Oct 19, 2009
- 3
My cousin recently gave me a 1975 25HP Johnson w electric start but electric start is disconnected. The engine had overheated and stalled out after the impeller failed - thats why he gave it to me. The engine would shift to neutral and turn over and the prop would turn prior to my replacing the impeller. After replacing impeller it seems that the drive shaft is locked in place. The shifter works and the shift rod moves up and down but it does not seem to go into neutral - i.e., when you shift to neutral and attempt to crank the gears appear to be locked up. If I drop the foot again and disconnect the shifter - you can shift to neutral or F or R by pressing up or down on the unattached shift rod. Also, the engine will turn over. It feels like the drive shaft is pressed too firmly into place when the foot is fully attached. What have I done wrong in reassembly? Can anyone offer advice or suggestions? Thanks.
Ed
Ed
