Im about to layup 1/2 plywood bed for a 60 gallon gas tank between stringers as it was originaly but I wonder should I build in a drain with a plug to the bilge area it would be accessable under IO engin cover
also I feel I should have air flow thru this area to remove condensation
I plan to install a blower just for the stringers and maybe an air scoop
intake and outlet as in the engin compartment .
does the gas tank compartment area have to be sealed off from the rest of the boat
Thanks
tryharder
Thanks
tryharder
