NEPATRIOTS
- Oct 17, 2009
- 5
I'm new to the forum but I have read all the great information people give here to other posters, I have a problem of my own. I have a 1974 Johnson V4 85 hp motor, the motor is on an 18 Ft Cobia sportster open bow, Hull is FBGLSS. The motor starts every time I turn the key and idles good, the problem is at wot i'm only getting 3000 rpm, I took the boat out last evening and when my Buddy went to the front the rpm went to 3800. The prop on the motor is 13/25/17 Aluminum. The numbers are as follows 85ESL74B ser # J4082983 4500 / 5000 RPM 85 HP 5000 RPM Johnson 1974 V4 85 HP like I was saying i'm only getting 3000 RPM and when my buddy sat in front the RPM went to 3800 However the Motor ran smooth no stumbling or power surges just steady. Took off air breather while running and held my hand over the set of carbs, the motor had noticeable change in idle, took spark plug wires off one at a time and the motor had noticeable change each time. Do I need another prop, and if so what pitch. Thank you
