Just curious, is this corrugated tin, v-crimp or a 36 inch residential crown panel ? If its the residential crown you put the screw in the rib. If the screws have the rubber washer in the flat of the tin. With the rubber washer it wont leak. Only place a screw in the lap rib. Look at the link below.
http://www.metalroofingwholesalers.com/installation.htm
