MidnightSpeedKC
- Sep 11, 2009
- 37
Had to order a new #2 cylinder Ignition Coil today. Got it on ebay for $25 shipped. Just thought I'd vent.
usually both do not go out at the same time. i would suspect power pack or charge coil under flywheel.
That engine has a low tension ign . 1 driver coil, 2 sets of points, 2 condensors, under the flywheel and 2 ign coils on the head. Pull the flywheel and inspect or change the points, they could be oil fouled. good luck.
