Re: disconnect vro to prevent engine damage?
This has been covered extensively multiple times, but, in my opinion, you have to read the pros and cons of each route and make your own decision. My 87 140 the VRO worked great, BUT water got into the resovoir, and oil floats on water, so water was pumped with the gas and that makes short life for a motor...
A properly maintained VRO pump (diaphram inspected and replaced as needed) is critical, and of course being sure water does not get into your resovoir.
My current rig is pre mix (85 140) with a 40 gallon tank, and I almost wish I had the VRO pump still hooked up cause its a pain to premix 40 gallons on the water...
The VRO system works great, and does not fail often, usually it is neglect, or like in my situation water getting in there or some other problem that leads to failure. The pump is not like Mecury pumps, as there is no gears, etc, it just a diaphragm in there...but like I said, premix can sometimes be kind of a pain...just my .02
