Hi guys. New to the forum, new to boating, and new to inflatable?s, but have been poking around here for some time searching the forum for info.
I have a new to me, but well used 15? Zodiac MKIII GR Model 3432 with aluminum floors and a month, year, model code of L586.
The intended use for this boat (I live in AK) is for a once a year fly-out moose / bear hunt (two guys), and perhaps 4 or 5 summer day / fishing trips with the family (5 total, wife, me, 2,4,6 year old boys) out of Seward, Homer, Deep Creek, or Whittier, weather permitting, and never out of sight of land (not exactly comfortable with ?big? water).
I purchased this as part of a package deal along with a trailer, two piece full length top, ores, anchor, and a 1985 Johnson 25hp short shaft motor for $1500, figuring that even if I needed to put another $500 each into the boat and motor, that I would still be way ahead money wise versus a new boat and motor, that start out around $6500 up here. Everything has been sitting in an unheated shed, all wrapped and bagged up for at least 10 years. That said, It looks to be in pretty good shape with only a few patches. The wood on the transom is perfect but the finish is chipped or flaking in a number of areas and will need to be sanded and have some new spar varnish applied. The two forward wooden cross beams (I don?t know what they are called) do not have any rot, however their finish is almost non existent and will need to be refinished somehow. Question: what are these cross beams called, and what are they for? I do know that the aft one, is were the forward most aluminum floor board attaches.
Additionally there is a trapezoid shaped wooden floor board with a hole in it that looks like it should fit up in the front of the boat, across or between the two wooden cross beams but it has three 1? x 1? pieces of wood attached to the bottom of it, that seems to prevent it from sitting, or fitting in between the two cross beams. It just doesn?t seem to fit worth a darn anywhere, and I cant figure it out?
I have inflated the boat, however I have not had a chance to soap it up and find the leaks. It looses perhaps 20-25% of the air pressure overnight and takes about a dozen or so pumps (each side) to firm it back up with the crappy foot pump I have. I am not especially worried about leaks or patching as I will be taking it in to Alaska Raft and Kayak and have those guys give it a good once over and fix anything that needs fixing, but they did tell me that they have no experience with the style of valves that are on this boat.
The valves are a rather large (hand size) chrome plated affair (four each) and they are REALLY stiff and hard to rotate. So, what can be done to loosen them up? Can I lube them with something?
A couple more questions:
From the data plate (L586) this looks to be a 1986 Zodiac, which I believe would make it a Hypolon boat, and not the newer PVC based ?strongam, strongarm, strongman? or what ever the proprietary name is. Can anyone confirm this?
There are two holes on the lower aft transom, and I know one is supposed to be the self bailing hole and the other the drain hole, but I don?t know which is which. They both appear to have some sort of gasket or valve in them.
Thanks in advance for your input and assistance!
