Re: Crossflow vs. Looper
The smaller engine(V4) will get better economy than the bigger engine(v6) , but you have to assume they are both in the same mechanical condition.
To clarify these odd-ball 2-stoke scavenging terms, a looper is what is more properly known as Schneurle scavenging; the piston top is either slightly crowned, or flat, and there is a pair or symetrical transfer ports in the cylinder that are opposite each other. They direct the incoming charge at the side of the cylinder wall that is directly oposite the exhaust, and there may also be some booster and auxilliary ports aimed at a much steeper angle towards the combustion chamber to "loop" the charge up and over the combustion chamber to sweep it clear of exhaust gasses.
Older "cross flow" engines have a baffle on the piston to direct the incoming charge from the transfer ports upwards towards the combustion chamber. Without this baffle, the charge would go straight towards the exhaust port and not fill the cylinder as effectively.
Typically, only high performance 2-cycles use Schneurle "loop charging". They usually have the exhaust port taking up about 40-50% of the stroke, making their corrected compression ratio no greater than about 6.7:1 max. The combustion chamber is a Hemispherical type with an angled squish band to quench the charge into the hemi dome for more efficeint burning due to the turbulence this creates.
Cross flow engines by contrast have very low exhaust ports that usually are only about 30-40% of the stroke, giving a higher effective compression ratio, and a longer power stroke, but they do not rev as high due to the baffled piston being quite heavy. This design is great for low end torque, and low speed trolling, and quite fuel efficient when compared to a Schnuerle of the same size, but not as powerful.
Cross flow was around for years, originally developed by Scott, Schneurle was developed in the late 1930s in Germany by Dr. Schneurle. Typically cross flow engines are long stroke, or square, while Schneurle "loopers" are either square or short stroke.
