flooring
21redboat
I have a 93 marada 5.8 it was left outside behind my work for years the gastank door (part of the floor) was missing the rest of the wood rails were rotted so i cut them out and part the floor was bad so i cut the bad parts out the foam underneath was wet i cut new plywood for the floor do i leave the foam or take it out i am also redoing the electric and all new wood side panels and (lots of other things) so i will need to find new like 3/8 foam and like waterproof pleather or whats best to do here please and thank you
d_saum
Re: flooring
I would absolutely replace the foam just to be on the safe side. It is most likely waterlogged. I'm not sure what you mean about 3/8 foam though. :confused: If you do a quick search on a site like west marine, or the store here at iboats.com, you should be able to find what you are looking for.
Also... an occasional period in your paragraph would help. :D
david_r
Re: flooring
you need to go and read some of the threads in boat restoration abd rebuilding........... you probably have more rot than you think
Bob_VT
Re: flooring
Do some reading here in restoration to see how far down you might have to investigate.
