just picked up an ancient 16 foot k model with an ancient sportsmen trailer--the steering console bolts to gunwhales and is across the whole boat in the back so the captain is isolated from the rest of boat and is in his own little cockpit--with the windshield it looks like a small cigarette boat--it looks cool as heck---also has a bow plate across top of front---i am working on pictures --were console and bow cover which are aluminum and same age standard or options?---here is where i really need some advice--the drain plug is a through the bottom contraption that really leaks--i took it apart and the hole is not a perfect circle-there is a small square shaped piece of bottom missing that is maybe part of the plug system or maybe it just broke away--the rubber stopper on the brass plug system is worn away--it has a cross handle that you push down or pull up--there is no spring in this plug like the old alumacraft ihave at the cottage--anyone know much about the plug on a k model--should the hole in boat be perfect circle?--thanks much-dont even need this boat but i luv it and am going to make her my new baby
