Re: Carpet on wood deck.
Henry 663 out door carpet adhesive from Home Depot or Lowe's. Put it on lightly with a notch trowel. Work in small stages at a time rolling the carpet over the glue as you go. If you get to a point where you have to stand on the carpet you just put down STOP, wait and let it set for a day then finish it the next day. This way your glue wont soak through the carpet and look like s---. Clean up any glue mistakes with acetone before it dries. Acetone will go to your head fast so work in a well ventilated area.
