Re: Elgin 1959 571.58791 7.5 hp stuck in gear?
UPDATE!!! FIXED!! I pulled the prop&housing. There hadn't been any oil in the lower end for some time. After some clean up we are ok to go. The neutral/drive system is spring loaded with 2 cable connections. The bottom cable section was "stuck", some penitrating oil and some heat on the outside of the housing finally allowed the bottom cable assembly to move, I was able to remove the cable/detent assembly from behind the top drive gear ... cleaned & lubed same. I see it calls for 30w oil in the housing... in this modern age are we using something better? (syntetic gear oil comes to mind?) Mike
