csisommout
- Nov 17, 2008
- 231
Hello,
I have 1964 speedtween cylinder, 2cycle and 28hp.
I try to disconnect the L U, It was stuck in gear before, now I disconnected cable, put it in reverse, it dropped down about 2". That is all i can lower it. where and how to disconect the shift rod from the motor?
I can not see a screw to loose it.
Thank you. note: I used to chnged impeller on Evinrude 1987 15hp before. This is different. Thank you.
Thank you.
Thank you.
