diver_down
- Apr 19, 2009
- 64
it ran marvelously for a while, we stopped for a dive that all of the sudden it would start but had no power, than quit completely.
brought home, started on muffs (surprise, surprise), checked the voltage across the yellow wires coming out of the stator. it fluctuates VERY MUCH, from like 5v to 20+ at idle. voltage across the output of the regulator is 8v only (12V when not running, just the key on). battery dies really fast while running (dropping voltage).
the resistance across those yellow stator wires is just a couple of ohms. My guess is that the stator is shot (and probably the regulator as well). I found them locally, used (functioning, motor threw a rod right through the block). now i need to take off the flywheel and can not figure out the size of the nut, can anybody help me with that.
also, any other ideas on what might be wrong would be appreciated.
it runs on muffs for a while, once warm the rpm drop and it quits, can't restart until it cools down completely.
p.s. i'm picking up the OEM manual on saturday as well.
