Re: ethanol gas & winterization
Jeff has it exactly right, use Start-Tron. It is the BEST thing you can use for treating Ethanol, and it will act as a full stabilizer for the fuel also. Always use new fuel/water separators in the Spring and you'll be good.
I usually double treat tanks when winterizing, just for extra Ethnol phase separation protection.
I don't know about the filling your tank theory, as to me that means if your fuel goes bad, then you will just have a full tank of bad fuel in the Spring. It always amazed me that people worry about condensation in their tank in the winter when the air is dry as can be, but not in the summer when the air is humid and the boat is sitting in the water. It would make more sense to keep a full tank of fuel in the summer than in the winter.
I have always left all boats with whatever is in the tank when I pulled it, and double treated and have never had an issue. A full tank is just that much more fuel to breakdown over time, especially with Etanol.
