Re: Force 150 on a Basstron 1760 ProVee
The five cylinder 150 was never made by Chrysler, however, the basic design and casting for the block is the same. It was made from 1989 by Brunswick AMF (who bought Chrysler and changed the name to Force) until 1994 by Mercury. It is a decent engine, with good power and should be relatively reliable. It uses 50 to 1 gas to oil mixture--no oil injection.
CFI means Cross Flow Injection (or induction--I forget which) and is a marketing hype to indicate and make sound good a dirt standard, old school design, crossflow inducted engine.
As far as condition, look at the general outside condition. Does it appear well kept or is there a lot of corrosion and flaking paint. Outside condition will generally mirror the overall condition of the engine.
Ask for compression ratio on all cylinders. All should be 140 or over and all should be within (ideally) 5 pounds of each other but 10 pound difference is acceptable.
Electronic components are easily replacable, so although a bit expensive, not too big a consideration. BUT: Low compression on one or more cylinders indicates a need for disassembly and rebuilding.
