Re: Fiber glass installation problems
What kind of fiberglass are you using? From my experience CSM especially the thicket stuff is a LOT harder to form to any sort of 90 degree angle. If you really don't want to round the edges of the 2x4 then I would suggest the use of some thinner woven. I have found that even the thick woven is easier to conform to curves than CSM.
Also get yourself a good laminating roller if your using woven. Roll out the bubbles as the resin is kicking, and keep rolling, and keep rolling.
