Is it ok to use Mercury high performence gear lube in a 2000 johnson 150?
B bkconlin Cadet Joined Aug 17, 2009 Messages 11 Oct 4, 2009 #1 Is it ok to use Mercury high performence gear lube in a 2000 johnson 150?
J jeff_smith_0423 Chief Petty Officer Joined Dec 5, 2007 Messages 492 Oct 5, 2009 #2 Re: High Performence Gear Lube That's good lube and I wouldn't be afraid to run it in anything.
B bkconlin Cadet Joined Aug 17, 2009 Messages 11 Oct 5, 2009 #3 Re: High Performence Gear Lube Thanks for the input. I had three quarts left from my Baja that I didn't want to let go to waste.
J jeff_smith_0423 Chief Petty Officer Joined Dec 5, 2007 Messages 492 Oct 6, 2009 #4 Re: High Performence Gear Lube I'm the same way. Especially when you have almost three seasons worth.
