I have a question I hope someone can help me clarify an overheating issue with my 1987 Wellcraft with a Merc. 3.7l closed cooling system engine. Went out last week after the boat was stored for 2 years, ran good for 2 hours then started to lose power at higher RPMs until the engine stopped and locked up. My temp gage never seemed to work correct since I bought it new but didn't show an overheat but this is what I suspect happened. Got towed out of the water as the starter just clicked and could not turn the engine over. Next day with the muffs on the engine started fine in the driveway. The coolant level in the engine is ok and I see no leaks. I took the lower unit apart assuming is was a sea water water pump issue and the pump I took out was in good shape but I replaced it anyhow. I noticed the the hose for the pump that is in the bellows area was kinked and I have Unkinked it with a fat Wire tie to hold it open and hoping this works as I see no way to change this hose without taking the boots apart. My ? is if I disconnect the hose from the sea water pump on the inside of the transom and run the engine with muffs how much water and pressure should I have at idle. When I checked this before it was pumping but not very hard, I feel it should be like a garden hose spray or an I wrong? The heat exchanger and the thermostat were replaced around 2 years ago so I feel they are ok. Any help would be appreciated as now after the repair I'm afraid to break down again.
Thanks,
Gman
Thanks,
Gman
