i need directions to change water pump on a 1982 115 johnson thanks
L lmdickens Cadet Joined Sep 22, 2009 Messages 27 Oct 2, 2009 #1 i need directions to change water pump on a 1982 115 johnson thanks
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Oct 3, 2009 #2 Re: Water Pump if you are extremely mechanically inclined. you have to release the shift rod under the bottom carb. then remove the 7 bolts on the lower unit.
L lmdickens Cadet Joined Sep 22, 2009 Messages 27 Oct 3, 2009 #3 Re: Water Pump thanks i thought there was an easier way .guess not will have to get some help
