pulley block
chumbucket
Will a pulley block assembly to set up double line system work on a hand winch or just power winch????
JB
Re: pulley block
Works fine on a hand winch too, Bucket. You have to crank a lot longer, but it is easier. :)
Bob_VT
Re: pulley block
As long as your support will the weight you are trying to pull. Do not try to pull more weight then the support is rated for or something may fail!<br /><br />I just installed a two speed winch to assist with the "heavier" portion of the pull.<br /><br />Bob
chumbucket
Re: pulley block
OK JB,Bob thanks. Just trying to make it a little easy to pull out. I only pull out after season . I dont trailer boat. Didnt want to invest in power winch. 20 grady about 3000lb give or take.
