Re: Lower carb leaking
He's tired of messing with it ay.Are you tired of it leaking,did you tell him so.Thats the unfortunate problem .Sometimes you can be intimiated by idiots that cant fix a problem leaveing you to think somehow its your fault.Again,I agree with the warped bowm or bad gasket or both.This guy should have figured it out.Its real imple too. He could swap the bowl/gasket with another carb,problem follows the part.Duh,he figured it out.Now if that leak was bad enough you could lean that cyl out and blow the eng.The idiot would likely rebuild the motor and send it out with a bad carb AGAIN.I feel for ya Bud.I swear I do.I get REAL pissed when I hear a MECHANIC cant fix a simple thing.Maybe he should bag groceries rather than put people on the water with confidence that they shouldnt have.Sometimes it a loose zip ty.Good luck and I apologize for my anger
