OMC/volvo sx trim pump
bruceb58
Re: OMC/volvo sx trim pump
Also, does it matter which side each hose is hooked up to?
Yes...unless you don't mind the drive trimming up when you press down on the switch! :)
It is also self bleeding. You rune the drive up and down to its limits a few times. All of this is in the service manual.
cr2k
ATF or motor oil work just fine.
