shattered piston
masse44
i recently asked for info but left out what motor i have it is a 200hp 2.5 liter xri black max mercury efi
Faztbullet
Re: shattered piston
Please post more information, usually piston failure is a fuel issue on a FI engine. Most likely you have a bad/clogged injector or ECU problem. Send injectors amd ECU to Tony Brucato @ Brucatosvs.com and have checked.
masse44
look ive just lost a 13000 dollar moter i asked for help fuel probelm is not helpful efi means eletronic fuel injection the fuel is mixed with oil correct so what is the fuel problem
coolguy147
look this is a volunteer site. we are just recommending possible causes for a piston failure.
the previous poster asked to post more info. all you gave us was the specs. how did happen? were you running this way or that way. etc etc did you do your maitence
