Hi,
I want to know what is the best to winterize my 96 50 hp engine. when fogging out the carbs should i use the primer coupling or spray the intake housing,
Use the Schrader valve on your primer solenoid with the attachment, then spray some through the spark plug holes. That way you don't gum up the carburetor.
