Feel N Good
- Aug 5, 2009
- 8
1. 07 Ebbtide Extreme
2. boat length 20.10 w/ext platform 23.2 beam 8.6, weight 3475lbs
2a. 320 hp
3. 2 adults (combined wt 300 lbs) 1 child 45 lbs, avg 35 gallons
4. occasional tube, mostly riding wide open
5. Deep Vee 20 degree
6. 07 5.7GXI Volvo
7. 320 hp 1.51 gear
8. 5200 rpm
9. n/a
10. pad, hull has been true'd
11. n/a
12. Volvo 14.75 x 19 (prop shopped tweaked added a little cup) prior to hul being true'd
13. 5350 (on the rev limiter) 58.5 mph prop part # 3858027 (old part number for Volvo) tested the following props this week after hull being true'd
Mirage Plus 19P - 5000 rpm - 54 mph
Mirage Plus 21P - 4650 rpm - 53 mph
Prior to hull being true'd
Enertia 21P - 4900 rpm - 55 mph, (stuggled to lift boat)
14. sea level
15. good
16. two years, testing props for maximum speed and performance.
17. no
18
19. overall best performance at maximum speed.
I have had access to several mercury props through the local mercury dealer, so I tested a few and the results are posted above. I was just wondering what could I expect if I put a Rev 4 on there? Any results on similiar boats??
Which pitch to start with??? The dealer here doesn't have any I can test so if he orders it, it is mine.
2a. 320 hp
6. 07 5.7GXI Volvo
7. 320 hp 1.51 gear
8. 5200 rpm
9. n/a
11. n/a
14. sea level
15. good
17. no
18
