I have a johnson 10hp outboard. 1962 or 63. When i run the motor, the glass fuel bulb turn to a milky white. I then dump it and prime clean fuel into the bulb. after running it turns back to milky white. the gas seems to be clean when i prime it. what is the problem? Another problem-The motor seems to not giving me the full 10 hp when throttle is open all the way. I checked the carburetor and it is open all the way. This has been happening before the milky fuel. What could this be? Thanks
