On a 95 Johnson 50hp should the fuel cap have a vent or no? Picked up a little rig 3-4 weeks ago and trying to sort out some issues with it. To start with it had sat too long and carbs had to be rebuilt. (The plugs are now wet after fishing trips and get home and check them.) Today I went out for awhile and after warming it up and going full throttle to plane out I noticed it was sluggish getting on plane. Stopped and fished about 2 hours and when cranking to move to another spot it didn't want to crank...even with using the auto primer. I checked the bulb and it was not primed. I pumped it up and noticed it would get about hard and then the next squeeze would go soft again. Got it primed and cranked and it wouldn't plane at all so I squeezed the bulb under full throttle and finally got it planed and sort of limped/hand pumped back to landing. I noticed the tank isn't vented and need to know if it should be. I realize I need a new primer bulb. Any suggestion on the wet plugs welcomed. I've tried adjusting the idle screws going by the sticky in the carb section of the forum. Thanks in advance guy's.
