harleyfool
- Jun 7, 2009
- 35
A follow up of a previous post:
4.3 GL Volvo - overheating since impeller replacement and despite intensive search (see previous post) I have been unable to find reason.
I removed thermostat and found engine temp gauge maxed out at 140 degrees. At the suggestion of another board member I picked up a temperature measuring device. He suggested an IR thermometer.
So this afternoon I start up the boat with muffs on. I let the engine heat up to 140 as noted on the boat's temperature gauge (no thermostat installed). I then started checking temperature readings on the external engine surfaces.
Thermostat housing - 95'
Hose from thermostat to water pump - 85'
Top of manifold - 80'
Lower portion of manifold closest to engine - 125'
Engine block area under valve cover 135'
My tongue - 91'
Boiling water on stove - 200'
So I am more confused. Sometime prior to the impeller packing it in the boat's temperature gauge maxed at about 160'. Now after my experiment I wonder if the sender/temp. gauge are faulty and perhaps under reading by 40' - but I'm not brave enough to reinstall the thermostat and run the boat to 200-220 to prove a point.
Any thoughts??
My tongue - 91'
Any thoughts??
