17ft cc starcraft. trying to wire the bow and stern light. for a test i put straight wires right to busbar pos and neg and both lights work fine.
i have on/off/on switch, put +12 to 2 center posts, bow and stern to up position and stern to down position. no lights work. tested middle and have power. i think i have no ground when switch is wired.
how do i get ground to switch? can i run wire from neg busbar to switch?
use what position, up or down?
thank you
thank you
