ParrishW,
Looks like a very nice well maintained motor. Have you checked out the outboard to make sure it is got good compression. If so then I would do the basic maintenance like replace the gear lube, spark plugs, replace the water pump impeller or whole water pump kit depending on what condition the water pump impeller is. Make sure the gas tank is clean and you might have to rebuild the carbs. I would highly suggest buying the OMC manual specific to your outboard and definitely stay away from Seloc/Clymers manuals. Let us know when your taking here out. I am interested in how well she is running. Have a Great day, Bob
