Re: how much tounge of trailer is needed
I guess I'm not correctly describing my trailer. the back set of rollers are about 24 inches apart (in line from front to back) and they sit on a bracket that is centered. There are 2 sets of them, right & left. the front set of rollers are about 12 in front of the rear trailer brace and the back set of rollers extend about 12 in past the end of the rear brace. When set up the boat the transom sits on the rear rollers. I plan on setting up the bunks the same distance from the rear bracket. I'll try and post some pictures tomorrow. I understand the transom has to sit on the rear rollers that is the reason I am going to bunks for better support of a alumimum boat
you will not get near the same support in your bunk set up as you do from your roller set up.... the structural strength of that bracket holding the roller gives way more support than a cantilevered BUNK..which could be a 2x6 with a laminate for easy sliding ( i am guessing).... the end of the bunk will sag
the greatest support from your bunk is right when it leaves the up right brace and it goes down hill the further it gets away from that up right support..
the roller set up has equal support at both ends of the pivoting bracket!!!!
and all the weight of the boat on the forward rollers give you the support out at the back roller under your transom.
the strength is in the design and ridgidity of the swivel bracket( probably 2x2 thick walled tubing in an upwards arc!!
trailers with swivel rollers brackets can get away with over hanging the frame..but bunks can so easily...
bow if your bunk boards...say a 2x6 was mounted VERTICALLY.. the bunks would have a BUNCH more strength...but i rarely see them mounted like that
I am trying to figure a trailer set up, myself
I thought your question might have been the same.
bob
