I just bought a 1982 4.5hp Johnson, that has seen very little use. It still looks like a new motor. I was told that it was overheating, and needed an impeller.
I took the bottom end off, .... checked them impeller, ... it is perfect. I reassembled it, making sure to put the tube in the water pump properly.
I put the motor in a tank.
The motor starts, and runs perfect, but the temperature climbs quickly. I shut it down at little over 230 degree head temp.(on a temp gun) I have a service manual that says the temp should be in the 160's.
The paint on the head bolts look like they have had a wrench on them. Could someone have put a head gasket on incorrectly, or were they just checking for a blockage!!!
Any ideas would be appreciated. Thanks.
