Re: 2001 40hp Merc rattling and not pumping water
Hi FaztBullet, Im just going to try to get it doing it again on the muffs so I can check that its not running backwards although thats far fetched. Wanted to check this before pulling it apart. I will replace the impella and t-stat this weekend, but what and where is the poppit valve? Cheers Matt
Interesting that your checking to see if it's starting backwards. I think it's an excellent check to do. The two cycle engine does have the ability to start and run either clockwise (forward) or counter clockwise (backward). If it wasn't for the devices that are dependent on the crankshaft and dependent on it's intended rotatational direction, it would do so quite well provided that ignition timing was properly compensated.
Since timing is not compensated in this case, if it is running backwards then timing would be reversed btdc becomes atdc and this could well be the source of the rattle. As for the waterpump failing to pump water, I'm not sure, I've never looked at it's design close enough to determine if it would or would not.
