I got the motor to work by spraying fuel into the carb. as soon as the fuel is burned up, it dies and will not start again. I have strong fuel source going from the fuel filter into the carb, but then I have no idea. What can I do for a fix, do I need to rebuild the carb, or can I use a carb cleaner that sprays in first to see if that clears it up?
