  #1
Old August 18th, 2004, 08:23 AM
ronskal ronskal is offline
Default Need cover for trailering new boat
To all:I just took delivery of a new SR 200 Select that came with a two piece snap-in cover. I asked two guys at the dealership and got two answers on whether I can trailer with it. The SR manual says not to trailer with it so I'm looking for a excellent quality towable cover. This site has some covers that are custom for my boat that I may look into.I plan on towing 3 hours each way to various lakes here in Texas and do not want to leave the boat wide open going down the highway.I store the boat inside so my top prority is a towable, secure cover.Thanks, Ron
  #2
Old August 18th, 2004, 03:35 PM
Richok Richok is offline
Default Re: Need cover for trailering new boat
ronskal I don't think I would cover it going down the road from what some of the guys here say the cover will beat your fiberglass. If you scroll through some of the pages you will come across this topic. Just a thought,its your boat though.
  #3
Old August 18th, 2004, 03:43 PM
DJ DJ is offline
Believe the manual, not the salesperson/dealer.The covers on this site are first rate and a good bargain.Covers can be made roadworthy.
  #4
Old August 18th, 2004, 05:05 PM
jlinder's Avatar
jlinder jlinder is offline
Master Chief Petty Officer
DJ,Which covers are you talking about? My experience in not that trailering with a cover on will beat the fiberglass, but that it beats the daylights out of the cover and quickly makes it worn out and rip.
  #5
Old August 18th, 2004, 05:19 PM
DJ DJ is offline
Jack,Covers such as the trailerable shark Skin covers offered here on iboats.Trailerable Semi-custom Fitting Boat CoversHurricane's Semi-Custom fitting boat covers are available in a variety of styles and sizes. This quality line of boat covers has wearing point reinforcements sewn to the underside of the cover at critical areas that otherwise will likely tear or wear through the cover such as windshields, bow noses, transom corners, etc. Even a unique strap & buckle tie down system is included. Multi-purpose boat covers also have double folded, lock-stitched, shock corded hems and sewn with U.V. rot resistant thread. Available in SHARKSKIN material. The trick is to get the heaviest material possible.ALSO, when attaching the straps to the trailer, put a "twist" in them where they touch the hull. The twist keeps them from vibrating in the wind (slipstream).
  #6
Old August 18th, 2004, 06:34 PM
I know this isn't the type of cover you are looking for, but if you go back to July 14, 2004 under boat topics & Questions(not engine) Look for blue tarp ruined my finish. BillP made a good statement about wind and covers.
  #7
Old August 18th, 2004, 09:36 PM
PAkev PAkev is offline
I made the mistake of trailering my boat with cover about 2hrs through a rain storm and found lots of chaffing from the wind beating the tiedowns against the hull. Although the cover manufacturer indicates the cover to withstand highway speeds, I do not tow with the cover on unless I am just going to the launch a half mile down the road. I would follow the manufactures recommendations and remove the cover before heading down the highway at 60+ mph.Kevin
  #8
Old August 19th, 2004, 09:41 AM
Thanks to all for the replies. I'll order a cover from Iboats and strap it down good. I'll keep an eye on it while traileringRon
  #9
Old August 19th, 2004, 09:59 AM
KM2 KM2 is offline
I agree with all of the statements posted above. I learned the hard way that a cheap cover and not tying it down properly is a big mistake. It does do a number on the boats finish. I tried traveling without a cover and that caused problems too. I have snap in carpet that was flapping around after it pulled a couple of screw snaps out and did some more damage to the interior. The best thing I have found is get a good cover that fits your boat well. Custom or semi custom. Get it tied down well and your straps should not touch the boat if it can be helped. I'm going to try that twisting of the straps tomorrow to prevent flapping. The flapping going on now is going to rub my staps on the trailer until they break, I can tell it's wearing them down. Kevin
  #10
Old August 19th, 2004, 11:36 AM
DJ DJ is offline
I'll repeat. Twist the tie down straps. Just make sure they have a half to one full twist throughout their length. They will not vibrate that way.That is an old truckers trick.
  #11
Old August 19th, 2004, 11:55 AM
Roger that on twisting the straps.Works on the straps for the bimini top also.
  #12
Old August 24th, 2004, 09:40 AM
KM2 KM2 is offline
Thanks for the strap twisting tip. It works great. Kevin
  #13
Old August 26th, 2004, 01:12 PM
garycinn garycinn is offline
I love these guys: http://www.basspro.com/servlet/catal...arget=brow se I have towed with them about 2500 miles so far and they are great. No slap, no marks, stay in place, and quick and easy. I double them up so they are close to the cover attach points and make sure the knob on the bungee is at the suction cup. The bungee's are getting worn, so I am going to replace with a short line.
  #14
Old August 28th, 2004, 11:48 AM
Scaaty's Avatar
Scaaty Scaaty is offline
Comment for thought...I use to own a 200HP Switzercraft that ran real damn close to 80mph...never forget getting ready to tow it home one day and the then "shefriend" asked me what to take out so nothing will blow out at 60 on the highway (yes, she was blond)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
The best material known to man for a trailering cover! T-290 Boat Topics and Questions (not engine topics) 6 August 5th, 2006 06:07 PM
Seeking recommendations for a good trailering boat cover manufacturer towdog Trailers and Towing 3 April 28th, 2006 05:40 PM
I have a trailering cover question too! craze1cars Trailers and Towing 8 May 17th, 2005 09:15 PM
Trailering with/without Cover SingleShot Trailers and Towing 9 August 7th, 2003 12:56 PM
Boat Cover for Trailering and Storage p sully Boat Topics and Questions (not engine topics) 2 July 23rd, 2003 04:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
