I have a 2004 Larson Senza 186 I/O (Mercruiser) and this summer my ignition switch literally fell apart in my hands. That same day, my electrical warning siren started to intermittently sound on and off. Not sure if they are related but while I was fumbling with the switch, the siren was on for about 25 minutes straight since the switch was stuck in the on position (engine was off). I replaced the switch and this didn't seem to fix anything. My gages all look okay and there are no obvious sights/sounds/smells eminating from my engine or lower unit. Siren seems to be worse at lower speeds and is more likely to go off when cruising slowly through channels and/or right after launch when the engine is first turned on. At higher speeds it is rare to hear the siren but when you do, it is usually for a very short time (<1s).
There is no pattern or rhythm to the siren sounding. It will be fine for long amounts of time then go on for a while, sometimes a few seconds sometimes for a minute or longer, then turn off. A service dealer suggested I try replacing the siren itself but I hate to go shotgunning parts without some debug. Any thoughts or ideas?
By the way, my engine is a carburated V8, GM build.
